BT.com
Wishlist
WD Blue 500GB  Mobile 7.0 MM Hard Disk Drive - 5400 RPM SATA 6 Gb/s  2.5 Inch - WD5000LPVX
WD Blue 500GB Mobile 7.0 MM Hard...
Price Drop
£40.17
Price Drop
Last Few Remaining
Price Drop
Hurry, only 1 left in stock!
£40.17
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
WD Blue WD5000LPVX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 7 mm
90 g
2 years warranty
500 GB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
7 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5"
Power Consumption
0.13 Watt (idle)
RoHS
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Sound Emission
17 dBA
WD Blue 500GB Mobile 7.0 MM Hard Disk Drive - 5400 RPM...
£40.17
Save on this ideal PC Build kit!
Save £10.36
£59.72
Cables - Cables
£40.17
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£43.77
Scroll to top
