BT.com
Wishlist
WD Blue 500GB Mobile Hard Disk Drive - 5400 RPM SATA 3 Gb/s 2.5 Inch - WD5000BPVT
Delivery
Standard Due date unavailable
WD Scorpio Blue
WD Blue drives are designed and manufactured with the proven technology found in WD's original award-winning desktop and mobile hard drives. Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs. These drives are available in a broad range of capacities, cache sizes, form factors and interfaces so you can be sure there's a drive that's the perfect fit for your system, in more ways than one.
WD Blue WD5000BPVT - hard drive - 500 GB - SATA 3Gb/s
Hard drive - internal
500 GB
2.5" x 1/8H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
Shock Guard, WhisperDrive, SecurePark, Advanced Format technology
70 mm x 100 mm x 9.5 mm
117 g
Microsoft Certification
Works with Windows Vista
2 years warranty
500 GB
2.5" x 1/8H
SATA 3Gb/s
Buffer Size
8 MB
70 mm
100 mm
9.5 mm
117 g
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
106 MBps
Track-to-Track Seek Time
2 ms
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 2.5" x 1/8H - internal
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
RoHS
60 °C
8 - 95%
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Scroll to top
