BT.com
Wishlist
WD Blue 4TB   Desktop  Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD40EZRZ
WD Blue 4TB Desktop Hard Disk...
£128.43
13 in stock
£128.43
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
High Capacity, Proven Reliability.
WD Blue hard drives deliver solid performance and reliability for desktops PCs, external enclosures and for certain industrial applications.
WD Blue WD40EZRZ - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
Data Lifeguard, IntelliSeek, NoTouch ramp load technology, Advanced Format technology
101.6 mm x 147 mm x 26.1 mm
680 g
2 years warranty
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
680 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
5.3 Watt (read) , 5.3 Watt (write) , 3.4 Watt (idle) , 0.4 Watt (stand by) , 0.4 Watt (sleep)
RoHS 2011/65/EU
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
250 g @ 2 ms
Sound Emission
25 dB
WD Blue 4TB Desktop Hard Disk Drive - 5400 RPM SATA...
£128.43
Save on this ideal PC Build kit!
Save £16.94
£153.81
Cables - Cables
£128.43
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.45
£131.88
Scroll to top
