BT.com
Wishlist
WD Blue 1TB Desktop Hard Disk Drive - 7200RPM SATA 6Gb/s 64MB Cache 3.5 Inch - WD10EZEX
WD Blue 1TB Desktop Hard Disk Drive...
Free delivery
£39.66
Free delivery
£39.66
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Built to WD's highest standards of quality and reliability, WD Blue offers the features and entry-level capacities that are ideal for your computing needs. WD Blue is designed by the brand that you trust with the quality you would expect for a tested, proven, everyday storage solution.
WD Blue WD10EZEX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
IntelliSeek, NoTouch ramp load technology
10.16 cm x 14.7 cm x 2.54 cm
440 g
2 years warranty
My Cloud EX2
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.16 cm
14.7 cm
2.54 cm
440 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
Sound Emission
29 dBA
WD My Cloud EX2
Accessories
£39.46
£77.10
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Solid drive...
Reviewed by Steve on 07/07/2014
I've had these drives for ages, both green and blue. The blue seems to be as quick as the black which is more expensive. Use the green drives as slave/backup drives as they go to sleep and save power, but take a few seconds to spin up when needed.
5* dabs excellent service
Reviewed by Anonymous on 19/03/2014
Hard drive arrived and installed in a few mins! does what it says on the tin would only purchase WD drives, as i have had seagate drives go down on me many times BUT never had 1 WD drive as yet... would also like to thank BT for there excellent service.....
Scroll to top
