BT.com
Wishlist
WD Blue 1TB  Mobile 9.5 MM Hard Disk Drive - 5400 RPM SATA 6 Gb/s  2.5 Inch - WD10JPVX
WD Blue 1TB Mobile 9.5 MM Hard...
£62.05
£62.05
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. This drive is designed for use as primary drives in notebooks and external enclosures.
WD Blue WD10JPVX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5400 rpm
NoTouch ramp load technology, Advanced Format technology
69.85 mm x 100.2 mm x 9.5 mm
90 g
2 years warranty
1 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
9.5 mm
90 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
144 MBps
Average Latency
5.5 ms
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
2.5" x 1/8H
RoHS
60 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
WD Blue 1TB Mobile 9.5 MM Hard Disk Drive - 5400 RPM...
£62.05
Save on this ideal PC Build kit!
Save £10.36
£81.60
Cables - Cables
£62.05
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£65.65
Scroll to top
