BT.com
Wishlist
WD Blue 1TB   Desktop  Hard Disk Drive - 5400 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch - WD10EZRZ
WD Blue 1TB Desktop Hard Disk...
£49.48
19 in stock
£49.48
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Monday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
High Capacity, Proven Reliability.
WD Blue hard drives deliver solid performance and reliability for desktops PCs, external enclosures and for certain industrial applications.
WD Blue WD10EZRZ - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
5400 rpm
Data Lifeguard, IntelliSeek, NoTouch ramp load technology, Advanced Format technology
101.6 mm x 147 mm x 26.1 mm
450 g
2 years warranty
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
5400 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1/3H
Power Consumption
3.3 Watt (read) , 3.3 Watt (write) , 2.5 Watt (idle) , 0.4 Watt (stand by) , 0.4 Watt (sleep)
RoHS 2011/65/EU
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
350 g @ 2 ms
Sound Emission
21 dB
WD Blue 1TB Desktop Hard Disk Drive - 5400 RPM SATA...
£49.48
Save on this ideal PC Build kit!
Save £10.36
£69.03
Cables - Cables
£49.48
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£53.08
Scroll to top
