BT.com
Wishlist
WD Black 750GB Performance Mobile Hard Disk Drive - 7200RPM SATA 6Gb/s 16MB Cache 2.5 Inch
Delivery
Standard 3-5 working days
WD Black hard drives are designed for enthusiasts and creative professionals looking for leading-edge performance. These 2.5-inch mobile drives are perfect for high-performance applications like photo and video editing, gaming and power PCs.
Maximum performance
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
No compromises
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
Industry-leading warranty
WD Black carries the highest available warranty protection on the market, a 5-year limited warranty.
Dual processor
Twice the processing power to maximize performance.
Dynamic cache
WD's dynamic caching algorithm improves performance in real time by optimizing cache allocation between reads and writes. For example, if there's an overwhelming percentage of read traffic as opposed to write traffic, the drive automatically allocates more cache for read data, which reduces congestion and improves overall drive performance.
Available SATA 6 Gb/s interface
The SATA 6 Gb/s interface provides greater flexibility for use with the latest chipsets as well as backwards compatibility to legacy systems with SATA 3 Gb/s requirements. (BPKX and BEKX models only).
Rock-solid mechanical architecture
NoTouch™ ramp load technology
The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
Tested for compatibility
We perform tests on hundreds of systems and a multitude of platforms in our FIT Lab™ to give our customers confidence that our drives will work in their systems.
WD Black Performance Hard Drive WD7500BPKX - hard drive - 750 GB - SATA 6Gb/s
Hard drive - internal
750 GB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
NoTouch ramp load technology, dual processor, Advanced Format technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 9.5 mm
115 g
5 years warranty
750 GB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
16 MB
69.85 mm
100.2 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
160 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Power Consumption
1.75 Watt (read) , 1.75 Watt (write) , 0.8 Watt (idle) , 0.2 Watt (standby) , 0.2 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
Shock Tolerance
350 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Sound Emission
28 dBA
Scroll to top
