BT.com
Wishlist
WD Black 500GB Performance Desktop  Hard Disk Drive - 7200 RPM SATA 6 Gb/s 64MB Cache 3.5 Inch
WD Black 500GB Performance Desktop...
£61.84
Select:
34 in stock
£61.84
Add to wishlist
Delivery
Standard 3-5 working days
Sophisticated performance enhancing features deliver the speed you need for demanding applications like photo and video editing and Internet gaming.
High performance, high capacity, high reliability, and cutting-edge technology make up WD Black, the ideal drive for those who demand only the best.
WD Black Performance Hard Drive WD5003AZEX - hard drive - 500 GB - SATA 6Gb/s
Hard drive - internal
500 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor
101.6 cm x 14.7 cm x 2.54 cm
440 g
5 years warranty
500 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 cm
14.7 cm
2.54 cm
440 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
6.8 Watt (active) , 6.1 Watt (idle) , 0.8 Watt (sleep)
RoHS
Limited warranty - 5 years
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 2ms (non-operating)
Sound Emission
30 dBA
WD Black 500GB Performance Desktop Hard Disk Drive -...
£61.84
Save on this ideal PC Build kit!
Save £8.40
£81.06
Cables - Cables
£61.84
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.27
£65.11
Other bundles
£61.84
Save on Intel Optane 16GB with HDD
Save £5.00
£100.81
Scroll to top
