BT.com
Wishlist
WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM Datacenter Hard Drive
WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM...
£357.86
16 in stock
£357.86
Add to wishlist
Delivery
Standard 1-3 working days
  • Specifically designed for use in enterprise servers, datacenter servers, and storage systems
  • Tested for 24x7x365 reliability at workloads up to 550TB per year
  • Performance-optimized for heavy application workloads
  • 5-year limited warranty
WD Gold Datacenter Hard Drive WD8002FRYZ - hard drive - 8 TB - SATA 6Gb/s
Hard drive - internal
8 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NAS compatible, 24x7 continuous operation, advanced format 512e, Dynamic fly height technology
101.6 mm x 147 mm x 26.1 mm
650 g
5 years warranty
8 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
Bytes per Sector
4096
101.6 mm
147 mm
26.1 mm
650 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
205 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,500,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
7.2 Watt (read) , 7 Watt (write) , 7.4 Watt (random read) , 5.1 Watt (idle)
Apple MacOS, Linux, Microsoft Windows Server, Microsoft Windows
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years , Technical support - phone consulting - 5 years
5 °C
60 °C
Shock Tolerance (operating)
70 g @ 2 ms half-sine wave
Shock Tolerance (non-operating)
300 g @ 1 ms half-sine wave
Sound Emission
20 dBA
WD 8TB Gold 3.5
WD 8TB Gold 3.5" SATA 6Gb/s 7200RPM Datacenter Hard...
£357.86
Save on this ideal PC Build kit!
Save £16.72
£383.03
Cables - Cables
WD 8TB Gold 3.5
£357.86
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.24
£361.10
Scroll to top
