BT.com
Wishlist
WD 6TB Red Pro NAS Hard Drive SATA 6Gb/s 3.5" 128MB
Delivery
Standard Due date unavailable
Joining the original color of NAS, WD Red Pro continues the formula of success that has led the WD Red product family by adding support beyond consumer and small business markets into medium and large 8-16 bay business storage systems. WD Red Pro hard drives integrate WD's exclusive technology, NASware, to provide unparalleled support for drive compatibility, reliability, and performance.
WD Red Pro NAS Hard Drive WD6002FFWX - hard drive - 6 TB - SATA 6Gb/s
Hard drive - internal
6 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), StableTrac, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
720 g
5 years warranty
6 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
720 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
226 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
10 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
9.1 Watt (read) , 9.1 Watt (write) , 5.8 Watt (idle) , 1 Watt (standby) , 1 Watt (sleep)
TUV Nord, RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
65 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Scroll to top
