BT.com
Wishlist
WD 500GB My Passport Studio USB 2.0 FW800 2.5" Portable Hard Drive
Delivery
Standard 3-5 working days
My Passport® Studio™ comes standard with two super-fast FireWire® 800 ports, massive capacity, and a MacBook®-inspired, metal enclosure that make this drive the ideal companion for Mac® professionals. Two FireWire 800 ports - With two super-fast FireWire® 800 ports, you can save and access data at top speeds. Use the second FireWire port to daisy chain an additional external drive or other peripheral to your Mac®. This drive also offers a USB 2.0 interface for added connectivity.
  • Premium aluminum enclosure - The durable, anodized aluminum enclosure is the perfect complement for your Mac® computer and resists scratching and fingerprints.
  • WD Security™-- WD Security utility allows you to set password protection and hardware encryption for your drive to protect your files from unauthorized use or access.
  • WD Drive Utilities™ - Register your drive, set drive security, run diagnostics and more using WD Drive Utilities.
  • Massive capacity, small enclosure- Offering massive capacity in a small metal enclosure, My Passport Studio is the ideal companion for the photographer, videographer, graphic artist, or creative professional on the go.
  • Formatted for Mac - HFS+ Journaled so it works right out of the box with your Mac computer. Can be reformatted for Windows®.
  • Compatible with Apple® Time Machine® - Back up your files with Apple Time Machine.
  • No power adapter required - The drive is powered through the FireWire or USB port, so there's no need to lug around a bulky power adapter.
  • WD quality inside and out - We know your data is important to you. So we build the drive inside to our demanding requirements for durability, shock tolerance, and long-term reliability. Then we protect the drive with a - robust enclosure designed for beauty and protection.
Ideal for
  • Transferring files with the blazing-fast FireWire® 800 interface
  • Adding extra storage for your videos, music, photos, and files
  • Using with your Mac® computer
  • Backing up your files with Apple® Time Machine®
  • Securing your files from unauthorized access with password protection and hardware encryption
Kit Contents
  • Portable hard drive
  • FireWire 800 cable
  • USB 2.0 cable
  • Quick Install Guide
Compatibility
  • Formatted for Mac OS® X, Leopard®, or Snow Leopard™, or Lion™
  • Windows® XP, Windows Vista®, or Windows 7 (requires reformatting) Compatibility may vary depending on user's hardware configuration and operating system.
WD My Passport Studio WDBALG5000ABK - hard drive - 500 GB - FireWire 800 / USB 2.0
Hard drive - external ( portable )
500 GB
Hardware Encryption
Data Transfer Rate
800 Mbps (FireWire 800) / 480 Mbps (USB 2.0)
Password authentication, hardware encryption
8.4 cm x 12.6 cm x 1.9 cm
250 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
3 years warranty
500 GB
Hardware Encryption
8.4 cm
12.6 cm
1.9 cm
250 g
Performance
Interface Transfer Rate
Expansion & Connectivity
2 x FireWire 800 , 1 x USB 2.0
Software Included
WD Security
Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X 10.7 Lion
1 x IEEE 1394 cable - external , 1 x USB cable - external
RoHS
Package Type
Retail
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
Resources
The following resources are available for the WD 500GB My Passport Studio USB 2.0 FW800 2.5" Portable Hard Drive
Scroll to top
