BT.com
Wishlist
WD 500GB My Passport Enterprise USB 3.0 Drive for Windows-To-Go
Delivery
Standard Due date unavailable
My Passport Enterprise is designed for Windows to go and allows you to boot your Windows 8 corporate workspace on any PC certified for use with Windows 7 or Windows 8.
Run the WD compass utility with existing Windows tools and the Windows 8 corporate desktop environment can be provisioned onto the My Passport Enterprise drive. Click and follow the simple steps. Your My Passport Enterprise drive will be provisioned in minutes.
Fast and easy setup
Run the WD Compass utility with existing Windows tools and the Windows 8 corporate desktop environment can be provisioned onto the My Passport Enterprise drive. Click here (http://www.wdc.com/wdcompass) and follow the simple steps. Your My Passport Enterprise drive will be provisioned in minutes.
Capacity and performance for Windows To Go
500 GB of storage space and exceptional performance in a sleek, compact enclosure that easily fits in your pocket. Secure work environment Securely transforms any compatible PC* into your employees' desktop workspace. The image is self-contained so there is no risk of confidential information being left behind on the host system. *Any PC certified for use with Windows 7 or Windows 8 operating systems.
Specifically designed to support Windows To Go
My Passport Enterprise is specifically designed for Windows To Go, a feature within Windows 8 Enterprise edition, offering portability, reliability and protection for the road warrior.
WD Compass
Instantly improve the provisioning time of Windows To Go on your My Passport Enterprise. With WD, installation time can be completed in minutes.
Plug-and-play solution for IT professionals
The easy set up process allows IT professionals to provision the Windows 8 corporate environment (using WD Compass) to users on the My Passport Enterprise. IT manages Windows To Go like a traditional desktop and users are able to operate Windows To Go from multiple managed or unmanaged PCs.
Up to 3X faster than USB 2.0
My Passport Enterprise offers ultra-fast data transfers and faster loading speeds for booting Windows To Go to your PC, allowing users to instantly access data in a plug-and-play mode. Performance may vary based on user's hardware and system configuration.
Drive encryption protects your data
Windows To Go supports BitLocker drive encryption. Data on the My Passport Enterprise separates itself from the host PC's internal hard drive to avoid any accidental data disclosure. It leaves no traces of data on the host computer so your information is secure. It allows IT to provide an imaged version of Windows 8 that reflects the Windows 8 corporate desktop environment.
On-the-go, ultra small
My Passport Enterprise was designed with mobility in mind. A compact, stylish and anti-fingerprint enclosure provides effortless portability and allows users to carry their data so they can easily boot and run Windows To Go to any computer certified for use with Windows 7 or Windows 8 operating systems.
PC ready
My Passport Enterprise is pre-formatted NTFS and works seamlessly with computers certified for use with Windows 7 or Windows 8.
No power adapter required
The drive is powered through the USB port, so there's no need to lug around a bulky power adapter.
WD quality inside and out
For over 20 years, millions of people worldwide have trusted their data to WD hard drives. We are successful because we understand the importance of your data and our first concern is keeping that data safe. WD is the only spinning media company with a dedicated SKU configured to support Windows To Go.
WD My Passport Enterprise WDBHEZ5000ABK - hard drive - 500 GB - USB 3.0
Hard drive - external (portable)
500 GB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Hardware encryption, NTFS formatted
Power Source
USB bus
Enclosure Colour
8.2 cm x 11.1 cm x 1.5 cm
138 g
Middle East, Africa, Europe
2 years warranty
500 GB
Hardware Encryption
USB 3.0
8.2 cm
11.1 cm
1.5 cm
138 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows 7, Windows 8
1 x USB cable
Plug and Play, RoHS, WEEE
Enclosure Colour
2 years warranty
5 °C
35 °C
Scroll to top
