Click to visit BT.com
BT.com
Wishlist
WD 4TB Enterprise Raid SE SATA 6GB/s 64MB 7200RPM 3.5"
Quicklinx: 8T1LWS00
Mfr#: WD4000F9YZ
Essential accessories
WD's SE hard drives provide an ideal solution for scaleout datacenters, delivering a cost-effective combination of performance, reliability, and workload capability while maintaining the hardiness of a true enterprise-class design. All WD datacenter storage devices are designed from the ground up to deliver optimal performance and maximum data integrity while running 24 x 7 x 365 in demanding multi-slot environments.
WD SE WD4000F9YZ - hard drive - 4 TB - SATA 6Gb/s
Hard drive - internal
4 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, StableTrac, NoTouch ramp load technology, dual processor, Advanced Format technology, Multi-axis shock sensor, Dynamic fly height technology , S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
750 g
5 years warranty
My Cloud EX4
4 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
750 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
171 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
1,000,000 hours
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bays
1 x 3.5" x 1/3H - internal
Power Consumption
9.5 Watt ( read ) , 9.5 Watt ( write ) , 8.1 Watt ( idle )
RoHS, NMB-3 Class B, CAN ICES-3 Class B
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
Sound Emission
31 dBA
WD My Cloud EX4
