BT.com
Wishlist
WD 4TB (2 x 2TB) USB 3.0 My Book Duo Premium RAID Storage
Delivery
Standard Due date unavailable
Transfer, save and protect your photos, videos, music and other massive files to free up valuable space on your computers. Featuring blazing-fast transfer speeds, local, cloud and system-level backup options, hardware RAID and password protection, My Book Duo is the ultimate storage solution offering the capacity and security you need.
WD My Book Duo WDBLWE0040JCH - hard drive array
Hard drive array
Total Array Capacity
4 TB
USB 3.0
2 (installed) / 2 (max)
Middle East, Africa, Europe
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 2 TB
Apple MacOS X, Microsoft Windows Vista / 7 / 8
AC 120/230 V - 50/60 Hz
Microsoft Certification
Compatible with Windows 7
9.9 cm x 15.7 cm x 16.5 cm
2.09 kg
2 years warranty
Hard drive array
Enclosure Colour
Charcoal grey
Chassis
2
Supported Devices / Modules Qty
2
Storage
4 TB
HDD Array External Interface
USB 3.0
Storage Controller
RAID
Data Transfer Rate
290 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
2 x 2 TB
Expansion Bays
2 (total) / 0 (free) x internal
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B
Hardware encryption, password security
1 x USB 3.0 cable
Software Included
WD Security, WD Drive Utilities, WD SmartWare Pro, Acronis True Image WD Edition
RoHS, AES-256
External power adapter
9.9 cm
15.7 cm
16.5 cm
2.09 kg
35 °C
Scroll to top
