BT.com
Wishlist
WD 4TB (2 x 2TB) My Book Thunderbolt Duo Dual-Drive
Delivery
Standard Due date unavailable
My Book® Thunderbolt™ Duo 4 TB dual-drive storage with RAID
My Book® Thunderbolt™ Duo, dual-drive storage system featuring revolutionary Thunderbolt™ technology, sets new standards for data transfer speeds and workflow flexibility in high-capacity storage.
Move data at unprecedented speeds
Finally, a drive that can keep up with your creativity. Video editors and other digital media professionals can do more work in less time with the ground-breaking data transfer speed of the Thunderbolt ports on My Book Thunderbolt Duo. It offers the indisputably fastest way to get information to and from your external drive.
Dual drive RAID storage system
User selectable RAID or JBOD modes. When set to RAID 0 (striping), My Book Thunderbolt Duo offers the performance you need when designing or editing graphics-intensive media files. When set to RAID 1 (mirroring), this drive provides double safe data protection by automatically generating a duplicate copy of your data. Set to JBOD (Just a Bunch Of Disks) to use as two individual drives and select between HFS+J or exFAT per disk. Ideal for running Windows OS on a Mac.
Dual Thunderbolt ports enhance workflow efficiency
Daisy chain up to seven devices or peripherals using the two Thunderbolt ports to achieve maximum workflow efficiency and productivity.
High-speed multi-tasking
The revolutionary bi-directional Thunderbolt technology delivers unmatched speed for multi-tasking while video editing, 3D rendering and completing other graphics-intensive projects.
User-serviceable
Want to replace a drive? Simply open the case and exchange the existing drive - no tools needed. If you fill up a drive, you can simply remove it and replace it with a fresh drive and begin saving even more of your creative life.
WD Drive Utilities™
Register your drive, run diagnostics, manage RAID or JBOD modes and more, using WD Drive Utilities.
Cool operation
Equipped with WD drives, this system is designed to run cool. Lower operating temperatures extend the life of the drive and improve data reliability.
  • Revolutionary Thunderbolt technology
  • Two Thunderbolt ports for high-speed multi-tasking
  • Dual-drive storage system with user-selectable RAID 0/1
  • User serviceable
Ideal for
  • Moving data at the unprecedented speeds of Thunderbolt™ technology
  • Daisy-chaining multiple devices like HD monitors, video and audio editors, media players and more through the dual Thunderbolt ports for nearly unlimited workflow efficiency and productivity
  • Multi-tasking while video editing, 3D rendering and completing other graphics-intensive projects
  • Enhancing system performance by setting to RAID 0 to boost speed
  • Protecting your data with user-selectable RAID 1 that automatically generates a duplicate copy of your data
  • Setting to JBOD to use the system as two individual drives
  • Selecting exFat to run Windows OS on a Mac®
Kit Contents
  • Dual-drive storage system with Thunderbolt connector
  • AC power adapter
  • Quick Install Guide
  • Thunderbolt cable must be purchased separately.
Compatibility
  • Formatted for Mac OS® X Lion™ or Snow Leopard® / Compatibility may vary depending upon user's hardware configuration and operating system.
  • Computer with Thunderbolt connector
  • Mac OS x 10.6.8 or higher
  • Thunderbolt cable (must be purchased separately)
Configuration
Configurable for maximum speed (RAID 0), data protection/mirror mode (RAID 1) or use the drives individually in JBOD mode
WD My Book Thunderbolt Duo WDBUPB0040JSL - hard drive array
Hard drive array
Total Array Capacity
4 TB
Thunderbolt
2 (installed) / 2 (max)
Middle East, Africa, Europe
Storage Controller
RAID - RAID 0, 1, JBOD
Hard Drive
2 x 2 TB HDD
Apple MacOS X 10.6.8 or later
9.9 cm x 15.7 cm x 16.5 cm
2.15 kg
3 years warranty
Hard drive array
Chassis
2
Supported Devices / Modules Qty
2
Storage
4 TB
HDD Array External Interface
Thunderbolt
Storage Controller
RAID
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 2 TB
Expansion Bays
2 (total) / 0 (free) - internal
2 x Thunderbolt
RoHS
External power adapter
9.9 cm
15.7 cm
16.5 cm
2.15 kg
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
35 °C
Resources
The following resources are available for the WD 4TB (2 x 2TB) My Book Thunderbolt Duo Dual-Drive
Scroll to top
