BT.com
Wishlist
WD 3TB Red NAS Desktop  Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX
WD 3TB Red NAS Desktop Hard Disk...
Free delivery
£104.53
Free delivery
18 in stock
£104.53
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Friday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
WD Red™: The colour of NAS.
WD Red is designed for NAS systems that have 1-8 drive bays. Available in capacities ranging from 1TB to 8TB, WD Red is designed specifically for home and small office NAS systems. The drives are extensively tested for compatibility and reliability in the demanding operating environment of a 24x7 NAS system. WD's exclusive NASware™ firmware technology enables seamless integration and balanced performance. Innovative technology reduces power comsumption and lowers the operating temperature, and with a 35% improvement in MTBF over desktop drives, WD Red is a more reliable and robust NAS hard drive solution.
• Designed specifcally for home and small office NAS systems - WD Red is the only hard drive for 1-8 bay systems
• Exclusive NASware™ technology - advanced firmware for seamless integration and optimal performance
• Energy efficient and reliable - Innovative technology reduces power consumption and operating temperature
WD Red NAS Hard Drive WD30EFRX - hard drive - 3 TB - SATA 6Gb/s
Hard drive - internal
3 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliPower, Advanced Format technology, NAS compatible, NASware technology, 3D Active Balance Plus, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
640 g
3 years warranty
My Cloud EX2; EX4
3 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
101.6 mm
147 mm
26.1 mm
640 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
147 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
Power Consumption
4.1 Watt (read) , 4.1 Watt (write) , 2.7 Watt (idle) , 0.4 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
65 g @ 2ms (operating) / 250 g @ 2ms (non-operating)
Sound Emission
23 dBA
WD My Cloud EX2 , WD My Cloud EX4
Cables - Cables
WD 3TB Red NAS Desktop Hard Disk Drive - Intellipower...
£104.53
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.25
£107.78
Other bundles
£104.53
Save on Intel Optane 16GB with HDD
Save £5.00
£142.83
Accessories
£37.15
£87.73
£87.52
Resources
The following resources are available for the WD 3TB Red NAS Desktop Hard Disk Drive - Intellipower SATA 6Gb/s 64MB Cache 3.5 Inch - WD30EFRX
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* WD 3TB Red SATA 6Gb/s 64MB 3.5" Hard Drive
Reviewed by John on 13/04/2013
A great and reliable hardrive for the job!
5* Finally a drive for NAS
Reviewed by Anonymous on 29/10/2012
This is a great drive for home users with a NAS (network attached storage).
I have a D-Link Sharecenter 320 running a pair of 1 year old regular drives and while ok they weren't built for the job, running hot and slow data rates.
I got the latest firmware from D-link, inserted the drive into the enclosure and it worked straight away without any problems.
So far data transfer rates are 3-4 times faster than the drives that were replaced and so far the drive hasn't needed cooling once.
Also given it comes with a 3 year warrenty from WD they are confident that these drives will do the job.
5* Inspire confidence
Reviewed by Dan P on 22/09/2014
Bought a pair of these to use as a 3TB RAID 1 array for my NAS enclosure.
They are fast, quiet, they run cool, and they are good value for money at £89 a piece. Also had nothing but good service from WD drives over the years, so am confident these will be the same.
5* Excellent
Reviewed by PavT on 30/07/2015
I got this drive to use as a mass backup / storage using a bare drive adapter. It is fast and quiet. Would thoroughly recommend it.
4* Fast and Quiet but had a failure
Reviewed by Anonymous on 11/08/2015
These drives are specifically designed for NAS drives and I purchased 2 in April 2013 for use in my Synology 213+ disk station running in RAID 1 mode.
In combination they have been quick quiet and efficient and I would have given them 5 stars.
However I just had one fail after just over two years use. The first sign was an intermitent "grinding" sound which soiunded like the fan failing. However a week later Disk 1 has fallen out of the RAID with bad sectors and disk unreachable errors.
Hopefully this isn't a sign of things to come with Disk 2.
Due to the failure within the wrranty period I'm dropping my score to 4 stars. It will be interesting to see how WD's warranty works in practice as the terms seem designed to make claiming difficult
Scroll to top
