Click to visit BT.com
BT.com
Wishlist
WD 3TB My Book Essential USB 3.0
My Book Essential Edition 3 TB Hard Drives
Quicklinx: 77W1WS00
Mfr#: WDBACW0030HBK-UESN
Put your digital life on the sleek, high capacity My Book Essential external hard drive. With WD quality and USB 3.0 and USB 2.0 connectivity, this drive is designed for today with tomorrow in mind.
A single drive with universal compatibility today and next-generation speed for tomorrow. Use it with USB 2.0 now and step up to USB 3.0 speed when you're ready.
When connected to a SuperSpeed USB 3.0 port this drive lets you access and save files up to 3 times faster than USB 2.0. Transfer a 2-hour HD movie in just 3 minutes instead of 13 minutes.
Password protection for privacy - gain peace of mind knowing that your data is protected from unauthorized access with password protection and encryption.
  • Dual USB 3.0 and USB 2.0 compatibility
  • Up to 3x faster transfer rates
  • WD SmartWare software
    You're in control of your backup. Install all the features, select just the components you need, or if you prefer, choose not to use the software at all.
  • Automatic, continuous backup
    Works quietly in the background to protect your data using minimal PC resources. Whenever you add or change a file it's instantly backed up.
  • Password protection for privacy
    Gain peace of mind knowing that your data is protected from unauthorized access with password protection and encryption.
WD My Book Essential WDBACW0030HBK - hard drive - 3 TB - USB 3.0
Hard drive - external ( desktop )
3 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Security lock slot (cable lock sold separately), password authentication, hardware encryption
Power Source
Included AC adapter
13.5 cm x 16.5 cm x 4.8 cm
1.18 kg
United Kingdom
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
2 years warranty
3 TB
Hardware Encryption
USB 3.0
13.5 cm
16.5 cm
4.8 cm
1.18 kg
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
Included AC adapter
Power adapter
AC 120/230 V ( 50/60 Hz )
Software Included
Smartware
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5
1 x USB cable - external
RoHS
United Kingdom
2 years warranty
Service & Support Details
5 °C
35 °C
