BT.com
Wishlist
WD 2TB RE Datacenter Hard Drive 3.5" SATA 6Gb/s 7200 rpm 128MB
WD 2TB RE Datacenter Hard Drive...
£124.41
24 in stock
£124.41
Add to wishlist
Delivery
Standard 1-3 working days
With advanced technology that delivers consistent high performance in a multitude of applications, and with ten times the workload capability of desktop drives, WD Re is the workhorse of the WD's datacenter portfolio. WD Re is perfect for high-availability storage arrays that demand the most robust storage device available. High performance, capacity and reliability make WD Re ideal for data warehousing/mining and high-performance computing.
WD RE WD2004FBYZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
3.5" x 1H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
128 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, NoTouch ramp load technology, Multi-axis shock sensor, Dynamic fly height technology, S.M.A.R.T.
101.6 mm x 147 mm x 26.1 mm
640 g
5 years warranty
2 TB
3.5" x 1H
SATA 6Gb/s
Buffer Size
128 MB
101.6 mm
147 mm
26.1 mm
640 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
200 MBps
Spindle Speed
7200 rpm
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^15
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s
Compatible Bay
3.5" x 1H
Power Consumption
7.4 Watt (read) , 7.4 Watt (write) , 8.1 Watt (active) , 5.9 Watt (idle)
RoHS 2011/65/EU, NMB-3 Class B, CAN ICES-3 Class B
5 years warranty
Limited warranty - 5 years
5 °C
60 °C
Shock Tolerance (operating)
30 g @ 2 ms
Shock Tolerance (non-operating)
300 g @ 2 ms
WD 2TB RE Datacenter Hard Drive 3.5" SATA 6Gb/s 7200...
£124.41
Save on this ideal PC Build kit!
Save £10.36
£143.96
Cables - Cables
£124.41
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.60
£128.01
Scroll to top
