BT.com
Wishlist
WD 2TB My Passport USB 3.0 Portable Hard Drive
Free delivery
Delivery
Standard Due date unavailable
Mini drive. Mega capacity.
My Passport 2TB comes in Midnight Black and offers high capacity in a slender, portable drive. It features ultra-fast USB 3.0 connectivity, compatibility with USB 2.0, automatic backup software, and password protection and hardware encryption to help protect your files from unauthorized use. The HUGE 2 TB capacity, means there's plenty of room to store all your files.
USB 3.0 transfers files up to 3x faster than USB 2.0 (When connected to a USB 3.0 Port)
  • 500 Photos: With USB 3.0 it's 54 seconds / With USB 2.0 it's 2 minutes 2 seconds
  • 2000 Songs: With USB 3.0 it's 4 minutes / With USB 2.0 it's 8 minutes 27 seconds
  • 2-hour HD Movie: With USB 3.0 it's 4 minutes 50 seconds / With USB 2.0 it's 14 minutes 27 seconds
  • Ultra-fast transfer rates: When connected to a USB 3.0 port, My Passport portable hard drives let you access and save files with blazing speed. Reduce transfer time by up to 3 times when compared to USB 2.0 transfer rates. Performance may vary based on user's hardware and system configuration.
  • USB 3.0 and USB 2.0 compatibility: With this single drive you get compatibility with your USB 2.0 devices today and the ultra-fast speed of USB 3.0 when you're ready to step up to the next generation.
  • High capacity, small design: Offering up to 2 TB capacity in a compact drive, My Passport is the ideal companion for anyone with lots of videos, photos, music and files that they want to help protect and take on the road.
  • USB-powered: Powered directly from the USB port on your PC. No separate power supply is needed.
  • Automatic, continuous backup: WD's automatic backup software works quietly in the background to help protect your data using minimal PC resources. Whenever you add or change a file, it's instantly backed up.
  • WD Security™: WD Security utility allows you to set password protection and hardware encryption for your drive to help protect your files from unauthorized use or access.
  • WD Drive Utilities™: Register your drive, set drive timer, run diagnostics and more using WD Drive Utilities.
Ideal for
  • Transferring files in blazing fast speed with USB 3.0
  • Connecting to USB 2.0 devices today and USB 3.0 devices when you're ready
  • Adding extra storage for your videos, music, photos, and files.
  • Backing up your files with automatic, continuous backup software
  • Securing your files from unauthorized access with password protection and hardware encryption
  • Connecting and powering through your USB 3.0 or USB 2.0 interface
Contents
  • Portable hard drive
  • USB cable
  • Quick Install Guide
Compatibility
  • Formatted NTFS for Windows® XP, Windows Vista®, Windows 7
  • Mac OS® X Leopard®, Snow Leopard™, or Lion™ (requires reformatting) Note: Compatibility may vary depending on user's hardware configuration and operating system.
Product Dimensions
  • Length: 111 mm
  • Width: 82 mm
  • Height: 21mm
  • Weight: 0.23 kg
WD My Passport WDBY8L0020BBK - hard drive - 2 TB - USB 3.0
Hard drive - external
2 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Hardware encryption, NTFS formatted
Power Source
USB bus
Enclosure Colour
8.2 cm x 11.1 cm x 2.1 cm
230 g
Middle East, Africa, Europe
Microsoft Certification
Compatible with Windows 7
2 years warranty
2 TB
Hardware Encryption
USB 3.0
8.2 cm
11.1 cm
2.1 cm
230 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0
Power Source
USB bus
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later
1 x USB cable
RoHS
Enclosure Colour
2 years warranty
5 °C
Scroll to top
