Click to visit BT.com
BT.com
Wishlist
WD 2TB My Book Live Personal Cloud Storage NAS
3.0*
My Book Live 2 TB Hard Drives
Quicklinx: 77V8WS00
Mfr#: WDBACG0020HCH-EESN
WD's My Book Live personal cloud storage provides shared storage on your home network that can be accessed wirelessly within and outside the home. Share files with Mac computers and PCs, stream media to your entertainment center, and access your files remotely with the WD 2go app and website.
WD My Book Live WDBACG0020HCH - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
5 cm x 13.9 cm x 16.7 cm
1.09 kg
Middle East, Africa, Europe
Hard Drive
1 x 2 TB
Network adapter 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Apple MacOS X 10.6, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
5 cm
13.9 cm
16.7 cm
1.09 kg
Hard Drive
HDD
1 x 2 TB
Network adapter
iTunes server, UPnP Media Server
DLNA CERTIFIED
1 x Ethernet 1000Base-T - RJ-45
1 x network cable
RoHS
X external power adapter
Software Included
Smartware
3 years warranty
Service & Support Details
Limited warranty - 3 years
5 °C
35 °C
Customer reviews
Write a review for the WD 2TB My Book Live Personal Cloud Storage NAS here!
WD 2TB My Book Live
Reviewed by Simon. Review Posted 10/06/2013
Easy to set up, just plug into router and go to WD website and download the software. Using a Mac it was very easy. Get the app for your smartphone and get access to all your data on the move. The Twonky software already on the drive works great with my Panasonic TV for streaming films. The drive is quiet when in operation and doesn't get hot.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
WD 2TB My Book Live
Reviewed by Anonymous Review Posted 23/05/2013
The installation appeared simple, but could not access at all with Windows XP computer even when eventually found software on website. Unit did connect to a Windows 7 system without little problem. Trying to connect remotely via the web required Java downloads on the remote computer - not clever if you are using someone else's computer. All help, including basic help, had to searched for on the WD website. It is far simpler to place all backups on a USB external hard drive and take it with you. A complete waste of time and money to me. I would recommend either use cloud or plugin hard drive for backing up.
  • Overall 1*
  • Ease of use 1*
  • Value for money 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
