BT.com
Wishlist
WD 250GB Blue SATA-600 7200RPM 16MB 3.5"
Delivery
Standard Due date unavailable
WD Caviar Blue
WD Blue hard drives deliver solid performance and reliability while providing you with all the space you need to hold an enormous amount of photos, videos and files. These drives are designed for use as primary drives in desktops PCs, external enclosures and for certain industrial applications.
WD Blue WD2500AAKX - hard drive - 250 GB - SATA 6Gb/s
Hard drive - internal
250 GB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Spindle Speed
7200 rpm
Shock Guard, IntelliSeek, NoTouch ramp load technology, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.5 cm
450 g
2 years warranty
250 GB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
16 MB
10.2 cm
14.7 cm
2.5 cm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
126 MBps
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
Scroll to top
