BT.com
Wishlist
WD 1TB Red SATA 6Gb/s 16MB 2.5" Hard Drive w/ WD Care Extended
Delivery
Standard Due date unavailable
WD's exclusive NASware technology, built into every WD Red hard drive, improves NAS storage performance by reducing common hard drive concerns in NAS systems including concerns for things like compatibility, integration, upgradeability, reliability and cost of ownership that are experienced with a hard drive designed for desktop computers.
WD Red NAS Hard Drive WD10JFCX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
2.5" x 1/8H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
16 MB
Native Command Queuing (NCQ), IntelliPower, Advanced Format technology, NAS compatible, NASware technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 9.5 mm
115 g
3 years warranty
1 TB
2.5" x 1/8H
SATA 6Gb/s
Buffer Size
16 MB
69.85 mm
100.2 mm
9.5 mm
115 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
144 MBps
Reliability
MTBF
1,000,000 hour(s)
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" x 1/8H
Power Consumption
1.4 Watt (read) , 1.4 Watt (write) , 0.6 Watt (idle) , 0.2 Watt (sleep)
RoHS
Limited warranty - 3 years
65 °C
Shock Tolerance
400 g @ 2ms (operating) / 1000 g @ 2ms (non-operating)
Sound Emission
24 dBA
Scroll to top
