BT.com
Wishlist
WD 1TB RE4 SATA-300 64MB 7200RPM 3.5"
Delivery
Standard Due date unavailable
WD RE4 enterprise SATA hard drives combine 64 MB cache with a SATA 3 GB/s transfer rate and dual stage actuation for lightning-fast performance in demanding server and storage applications. Technologically advanced acoustics minimize noise. Cool drive operation and enhanced reliability features help protect the drive and the data stored on it.
WD RE4 WD1003FBYX - hard drive - 1 TB - SATA 3Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 3Gb/s
Data Transfer Rate
300 MBps
Buffer Size
64 MB
Spindle Speed
7200 rpm
Shock sensor, Rotary Acceleration Feed Forward (RAFF), Time-Limited Error Recovery (TLER), dual actuator technology, IntelliSeek, StableTrac, Perpendicular Magnetic Recording (PMR), Active Power Save, NoTouch ramp load technology, dual processor , S.M.A.R.T.
10.2 cm x 14.7 cm x 2.6 cm
0.73 kg
5 years warranty
My Cloud EX2; EX4
1 TB
3.5" x 1/3H
SATA 3Gb/s
Buffer Size
64 MB
Bytes per Sector
512
10.2 cm
14.7 cm
2.6 cm
0.73 kg
Performance
Drive Transfer Rate
300 MBps (external)
Internal Data Rate
128 MBps
Average Latency
4.2 ms
Spindle Speed
7200 rpm
Reliability
Non-Recoverable Errors
1 per 10^15
Start / Stop Cycles
600,000
Expansion & Connectivity
1 x SATA 3 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
Limited warranty - 5 years
5 °C
55 °C
Shock Tolerance
65 g @ 2ms (operating) / 300 g @ 2ms (non-operating)
WD My Cloud EX2 , WD My Cloud EX4
Scroll to top
