BT.com
Wishlist
WD 1TB Green SATA 6Gb/s 64MB 3.5" Hard Drive
Delivery
Standard Due date unavailable
WD Green storage is designed specifically with reliability in mind for an increased drive lifespan. The advantage of being cool and quiet impacts overall reliability while reduced heat output, decreased power consumption, quiet acoustics, and best-in-class power management make WD Green a leader when compared to the competition.
WD Green WD10EZRX - hard drive - 1 TB - SATA 6Gb/s
Hard drive - internal
1 TB
3.5" x 1/3H
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
64 MB
IntelliSeek, IntelliPower, NoTouch ramp load technology, GreenPower technology, Advanced Format technology, S.M.A.R.T.
10.2 cm x 14.7 cm x 2.5 cm
450 g
2 years warranty
1 TB
3.5" x 1/3H
SATA 6Gb/s
Buffer Size
64 MB
10.2 cm
14.7 cm
2.5 cm
450 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
150 MBps
Reliability
Non-Recoverable Errors
1 per 10^14
Start / Stop Cycles
300,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
3.5" x 1/3H
RoHS
60 °C
Shock Tolerance
65 g @ 2ms (operating) / 350 g @ 1ms (non-operating)
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent Drive for the money
Reviewed by Anonymous on 20/10/2014
I have two of these drives and I've never had a problem with them.
4* Great drive for the money
Reviewed by Niki on 08/03/2013
Excellent value for money. These drives are cheap, quiet and save energy! They do spin down if you leave them alone, so maybe not the drive for everyone. Also, unlike the last reviewer, note the price! Yes, these are cheap drives. You can't expect enterprise quality in a drive that's so cheap. If you want something better, get one of the WD Black series.
4* A good reliable drive
Reviewed by Anonymous on 05/06/2014
I have these hard drives as slaves which is what they are meant for. They shut down when not in use, so when you access explorer and click on the relevant drive, it takes about 4 seconds to wake up. Not a problem for me as the drive is low power and will increase the life of the unit.
1* Load of trash!
Reviewed by Miles on 06/02/2013
This drive is just a clear example of the poor quality products Western Digital provide! I needed a large drive to store music, pictures and videos on and to use as a back up but after 3months the drive has died and i have lost all my data! Dont waste your money or data on this cheap rubbish!
1* Dreadful
Reviewed by Ian Johnston on 28/02/2015
I have had two of these. The first was dead on arrival and the replacement died after about 50GB had been copied onto it the day I installed it on a Zyxel NAS. Perhaps I was just very, very unlucky, but I would certainly not even think about buying anther one of these. BT service excellent, by the way, and both accepted for return with no quibble.
Scroll to top
