BT.com
Wishlist
WD 16TB (2x8TB) My Book Pro 2bay Desktop NAS Thunderbolt USB3.0
Delivery
Standard Due date unavailable
My Book desktop storage is optimized for the best possible data transfer rates. Connect this drive to a SuperSpeed USB 3.0 port to save and access files up to 3x faster than with USB 2.0. My Book offers complete backup options with WD SmartWare Pro software for local and cloud backup and Acronis True Image WD Edition software for system level backup. Gain peace of mind knowing that your data is protected from unauthorized access with password protection and hardware encryption. WD's Windows 8 app makes it easy to discover the digital media stored on your My Book drive with your Windows 8 computer. Your content is automatically displayed and organized so you can easily locate and enjoy your photos, videos and music. With this drive you get connectivity with the latest USB 3.0 devices as well as backward compatibility with USB 2.0 devices. With up to 6 TB capacity, there's plenty of room to store and protect your precious memories and important files. Use WD Security to set password protection and hardware encryption. Gain peace of mind knowing that your data is protected from unauthorized access.
WD My Book Pro WDBDTB0160JSL - hard drive array
Hard drive array
Total Array Capacity
16 TB
USB 3.0, Thunderbolt 2
2 (installed) / 2 (max)
EMEA
Storage Controller
RAID RAID 0, 1, JBOD
Hard Drive
2 x 8 TB HDD - hot-swap - Apple Time Machine compatible, HFS+ formatted, toolless
Microsoft Windows 7 or later, Apple MacOS X 10.7 or later
AC 120/230 V - 50/60 Hz
10.86 cm x 21.61 cm x 14.78 cm
3.5 kg
3 years warranty
Hard drive array
Enclosure Colour
Black and silver
EMEA
Chassis
2
Supported Devices / Modules Qty
2
Storage
16 TB
HDD Array External Interface
Xeon
Storage Controller
RAID
Data Transfer Rate
435 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 8 TB
Spindle Speed
7200 rpm
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x USB 3.0 - 9 pin USB Type A , 1 x USB 3.0 - 10 pin Micro-USB Type B , 2 x Thunderbolt 2
Security lock slot (cable lock sold separately), metal housing
1 x USB 3.0 cable , 1 x Thunderbolt cable - 1 m
Software Included
WD Drive Utilities
RoHS
External power adapter
10.86 cm
21.61 cm
14.78 cm
3.5 kg
Limited warranty - 3 years
35 °C
Scroll to top
