BT.com
Wishlist
WatchGuard Technologies XTM 515 UTM 1 Year
Delivery
Standard Due date unavailable
Get everything you need for complete unified threat management at a great price with the XTM 515 Security Bundle. The Bundle includes a next-generation WatchGuard XTM 515 security appliance with 2.0 Gbps firewall throughput, 210 Mbps VPN throughput, and six 1GgE ports. In addition, the Bundle delivers a full suite of UTM security subscriptions to boost protection in critical attack areas, including Application Control, Intrusion Prevention Service, WebBlocker, Gateway AntiVirus, spamBlocker, and Reputation Enabled Defense, along with LiveSecurity Plus for 24/7 technical support.
WatchGuard XTM 5 Series 515 - security appliance - with 1 year Gateway AV/IPS, Application Control, spamBlocker, WebBlocker, Reputation Enabled Defense, LiveSecurity Plus Service Subscriptions
Security appliance
Bundled Services
External - 1U
Ports Qty
7
Performance
Firewall throughput: 2 Gbps , VPN throughput: 210 Mbps , Antivirus throughput: 1.52 Gbps , IPS throughput: 900 Mbps , Aggregate throughput: 660 Mbps , Throughput: 12000 connections per second
Virtual interfaces (VLANs): 100 , Concurrent connections: 40000 , Nodes (LAN IPs): unlimited , Authenticated users: 500 , Branch office VPN tunnels: 65 , Mobile IPSec VPN tunnels: 75 , Mobile SSL VPN tunnels: 65
VoIP Protocols
H.323, SIP
43.2 cm x 28.6 cm x 4.5 cm
7.3 kg
Security appliance
Bundled Services
Height (Rack Units)
1U
Built-in Devices
Status LCD
43.2 cm
28.6 cm
4.5 cm
7.3 kg
External
Ports Qty
7
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
PPTP, PPPoE, FTP, DNS, POP3, DDNS
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Performance
Status Indicators
Power, status, link/activity
DoS attack prevention, DiffServ support, IPv6 support, Quality of Service (QoS), VPN failover, DHCP server, anti-spyware protection, DHCP relay, DHCP client
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
SecurID, VASCO token authentication, Transparent Active Directory Authentication (Single Sign-on), XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
VoIP Protocols
H.323, SIP
1 x console , 2 x management , 6 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45
Rack Mounting Kit
Included
MTBF
51,644 hours
CB, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, NRTL
Internal power supply
10 - 85% (non-condensing)
Scroll to top
