BT.com
Wishlist
WASP WPS200 Omni Directional Scanner with Stand
WASP WPS200 Omni Directional...
£264.64
Hurry, only 2 left in stock!
£264.64
Add to wishlist
Delivery
Standard 1-3 working days
The Wasp WPS200 Omni-Directional barcode scanner is a high performance scanner ideal for retail point-of-sale (POS) and warehouse applications. Utilizing a digital imaging scan engine, the WPS200 is capable of reading both 1D and 2D barcodes with ease. Unique Illumination technology optimizes light levels and provides the ability to read barcodes from mobile phones, tablets, and computer displays.
For busy retail environments, the WPS200 can be used in hands-free and handheld mode. Checkout personnel simply wave the barcode label or tag across the face of the scanner. Regardless of barcode label orientation, the WPS200 Omni-Directional scan engine will quickly read the barcode and assist in the rapid check out of your customers.
The WPS200 Omni-Directional barcode scanner can also be used to scan invoices or pick lists and is a perfect addition to any warehouse. Its rugged housing can withstand repeated 4 foot drops to concrete, and is sealed against moisture and dust (IP52 particulate and water sealing rating). For noisy environments, the WPS200 provides visual feedback, perfect for confirming a positive scan or for precise targeting of a single barcode from a group of barcodes.
Wasp WPS200 Omni-Directional - barcode scanner
Barcode scanner - desktop - stationary - USB - decoded
Minimum Bar Width
5 mil
Scan Field Width
17.8 cm
Scan Element Type
Visible laser diode
Scan Speed
1768 scan / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
8.86 cm x 7.52 cm x 14 cm
385.6 g
2 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Field Width
17.8 cm
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Fixed projection
Scan Speed
1768 scan / sec
Max Working Distance
21.6 cm
Decode Capability
EAN/JAN, Code 93, Code 39, UCC/EAN-128, ISBT 128, QR code, MaxiCode, Aztec code, UPC-A, Discrete 2 of 5, MicroPDF417, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, PDF417, MSI-Plessey, Data Matrix, Code 39 Trioptic, Hong Kong 2 of 5
TTL Decoding
Decoded
Wired
Reduced Space Symbology (RSS)
1 x USB - Type A
Stand
1 x USB cable - external
FCC Class B certified, CISPR 22 Class B, UL 1950, CSA 22.2 No. 950, EMC, EN 60825, IP52
Electric Current Required
275 mA (operating)
8.86 cm
7.52 cm
14 cm
385.6 g
5 - 95% (non-condensing)
Drop Specification
1.2 m to concrete
Scroll to top
