BT.com
Wishlist
WASP WPL406 Industrial Barcode Printer with Peeler
WASP WPL406 Industrial Barcode...
£671.46
£671.46
Add to wishlist
Delivery
Standard Due date unavailable
The WPL406 industrial barcode printer features a low profile, industrial design at an affordable price; and delivers the reliability your organization can depend on. Featuring an all-metal exterior housing and die-cast aluminum print mechanism, the WPL406 can withstand even the harshest of conditions. Print speed of up to 6 inches per second at 203 dpi resolution is supported by 8 MB of SDRAM, and 4 MB of Flash memory, making the WPL406 ideal for high volume print applications. The WPL406 industrial barcode printer includes a LCD display, with 6-button control panel for easy installation and use. The WPL406 is also RoHS compliant.
Wasp WPL406 - label printer - monochrome - direct thermal / thermal transfer
Printer Type
Label printer - direct thermal / thermal transfer - monochrome
11 kg
Max Media Size
Roll (11.8 cm)
Min Media Size (Custom)
25 mm
Max Media Size (Custom)
118 mm
Print Speed
Up to 152 mm/sec
Max Resolution (B&W)
203 dpi
USB, LAN, serial
RAM Installed (Max)
8 MB SDRAM
Flash Memory Installed (Max)
4 MB
Language Simulation
ZPL, EPL, WPL
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, LOGMARS, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 11, Interleaved 2 of 5, Postnet, PDF417, MSI-Plessey, Data Matrix, Code 128B, Code 128C, Code 128A
Media Type
Labels
Peeler
Print server
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows 2000/XP/Vista/7/8
2 years warranty
28.6 cm x 43.4 cm x 25.9 cm
Printer Type
Printer
Print Speed
Up to 152 mm/sec - 203 dpi
Built-in Devices
Status LCD, peeler
Wired
USB, LAN, serial
203 dpi
Language Simulation
ZPL, EPL, WPL
Peeler
Barcodes
RAM
RAM Installed (Max)
8 MB
Technology / Form Factor
SDRAM
Flash Memory
Flash Memory
4 MB
Media Handling
Media Type
Labels
Max Media Size
Roll (11.8 cm)
25 mm
118 mm
Media Sizes
Roll (11.8 cm)
Max Printing Width
106 mm
Max Printing Length
2286 mm
Roll Maximum Outer Diameter
208 mm
Roll Core Diameter
76.2 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
1 x serial , 1 x USB , 1 x LAN
1 x USB cable
Consumables Included
1 x ribbon
FCC Class A certified, UL, TUV, cUL, CCC, C-Tick Class A
5 °C
28.6 cm
43.4 cm
25.9 cm
11 kg
Scroll to top
