BT.com
Wishlist
WASP WLS9600 Laser Barcode Scanner
£173.04
19 in stock
£173.04
Add to wishlist
Delivery
Standard 1-3 working days
The Wasp WLS9600 laser barcode scanner makes it simple to add barcode data to spreadsheets, word processing documents or databases. Just connect the WLS9600 to your PC (USB, RS-232, Keyboard Wedge, IBM 46XX and Wand Emulation), and you're ready to begin scanning barcodes. The WLS9600 features a laser scan engine for rapid, error-free data entry. Easily read all common 1D barcodes, including damaged symbols or stacked RSS barcodes. The WLS9600 offers aggressive reading performance, with over 100 scans per second, and a patented "Green Spot" technology for good-read feedback; making the scanner extremely easy to use. Fast scan rate and dynamic decoding capabilities ensure employees are able to scan items quickly and, as a result, spend less time keying in data.
Wasp WLS 9600 Laser Scanner - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
5 mil
Scan Field Width
3.6 cm - 69 cm
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
7.1 cm x 18.1 cm x 10 cm
169 g
2 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
5 mil
Scan Field Width
3.6 cm - 69 cm
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Decode Capability
Code 93, GS1 DataBar, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, MSI-Plessey, China Post, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
TTL Decoding
Decoded
Wired
Reduced Space Symbology (RSS), Green Spot technology
1 x USB
1 x USB cable - 1.83 m
IEC 60825-1, CDRH Class II
Electric Current Required
260 mA (operating)
7.1 cm
18.1 cm
10 cm
169 g
Limited warranty - 2 years , Technical support - unlimited
55 °C
5 - 90% (non-condensing)
Drop Specification
1.8 m to concrete
Scroll to top
