BT.com
Wishlist
WASP WLS8600 Industrial Barcode Scanner w/ USB
WASP WLS8600 Industrial Barcode...
£389.35
£389.35
Add to wishlist
Delivery
Standard Due date unavailable
The Wasp WLS8600 industrial barcode scanner features fuzzy logic technology for fast, accurate reading of damaged, dirty, and poorly printed one-dimensional (1D) barcodes typically found in industrial environments. In the yard, warehouse, distribution center, manufacturing plant or retail store, the WLS8600 industrial barcode scanner offers superior performance, reliability, and user-friendly ergonomics to improve productivity. Multiple on-board interfaces ensure flexible plug-and-play host connectivity.
Wasp WLS8600 Fuzzy Logic - barcode scanner
Barcode scanner - handheld - USB - decoded
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Scan Speed
35 scan / sec
Wired
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits)
6.9 cm x 11.4 cm x 20.7 cm
295 g
2 years warranty
Barcode
Interface Type
USB
Minimum Bar Width
3 mil
Scan Element Type
Visible laser diode
Light Source Wave Length
630-680 nm
Scan Speed
35 scan / sec
Max Working Distance
97.8 cm
Print Contrast Signal (PCS)
15%
Decode Capability
Code 49, RSS Code, Code 16K, GS1 DataBar Stacked Omnidirectional, GS1 DataBar Expanded Stacked, GS1 DataBar Stacked
TTL Decoding
Decoded
Wired
OK Notification
LED indicator
Reduced Space Symbology (RSS), waterproof, rugged
1 x USB - Type A
1 x USB cable - 1.83 m
RoHS, IP65
6.9 cm
11.4 cm
20.7 cm
295 g
2 years warranty
Service & Support Details
Limited warranty - 2 years , Technical support - lifetime
-30 °C
50 °C
0 - 90% (non-condensing)
Drop Specification
2 m to concrete
Scroll to top
