BT.com
Wishlist
WASP Upgrade to Wasp Labeler +2D v7
WASP Upgrade to Wasp Labeler +2D...
£62.10
£62.10
Add to wishlist
Delivery
Standard Due date unavailable
WaspLabeler +2D is an easy to use solution for designing, creating, and printing barcode labels. Select from more than 100 pre-designed label templates, build a custom label, or start from scratch on your own design. Manually input or easily connect to an external data source.
With WaspLabeler +2D's intuitive interface, you can quickly create inventory barcodes, asset tags, product shipping/mailing labels, and more. Easily combine text, company logos, and barcodes to create the barcode label you need. Generate barcode scan sheets or shadow books so that barcodes for small or difficult to tag items are readily accessible. WaspLabeler +2D is designed to improve the efficiency and accuracy of your business.
WaspLabeler +2D (v. 7) - box pack (version upgrade)
Box pack (version upgrade)
Category
Creativity application - creativity - labelling / barcode software
Version
7
Licence Qty
1 user
Platform
Windows
Category
Creativity application - labelling / barcode software
Version
7
Platform
Windows
Licencing
Licence Type
1 user
Supported OS
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows XP SP3, Microsoft Windows Vista / 7
Hardware Requirements
RAM 512 MB - HD 2 GB
Additional Requirements
CD-ROM, XGA monitor
Scroll to top
