BT.com
Wishlist
WASP InventoryCtrl RF Pro w/ HC1 Mobile Computer & WPL305 BCode P
WASP InventoryCtrl RF Pro w/ HC1...
£689.68
£689.68
Add to wishlist
Delivery
Standard Due date unavailable
Get in control of your stock with Wasp Inventory Control - the complete stock management solution for small business. Increase the value of your business, satisfy your customers and create more freedom in your life with Inventory Control.
Engineered to improve efficiency and profitability, Wasp Inventory Control provides the capabilities you need to accurately track stock, without the complexity or expense of an enterprise solution. Easy, efficient, affordable!
Inventory Control allows you to define multiple sites (a warehouse, truck fleet, stock room, or even an installation truck such as a TV or satellite installer) with multiple locations (a bin, shelf, or even a pallet within the location). It's simple to track your stock by location, serial number, lot or any combination of the numerous 'track bys'.
Easily create barcode labels with Wasp Inventory Control. Print barcode labels or stock tags using data from the Inventory Control database. Attach barcoded labels to stock items, physical locations or pallets to quickly improve efficiency.
Inventory Control RF Professional - box pack
Box pack
Category
Business applications - business - inventory systems
Bundled with
HC1 & WPL305
Licence Qty
1 mobile device, 5 PCs
Platform
Windows, Pocket PC
Distribution Media
DVD-ROM
Technical support
Category
Business applications - inventory systems
Box pack
Bundled with
HC1 & WPL305
Platform
Windows, Pocket PC
Distribution Media
DVD-ROM
Min Supported Colour Depth
8-bit (256 colours)
Licencing
Licence Type
Supported OS
Microsoft Windows XP Professional x64 Edition SP3, Microsoft Windows Vista Home Premium (32/64 bits), Microsoft Windows XP Professional SP3, Microsoft Windows 7 Professional (32/64 bits), Microsoft Windows CE 4.2 or later, Microsoft Windows Mobile for Pocket PC 2003 or later, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Embedded Handheld 6.5, Windows 8
Hardware Requirements
Microsoft Windows Server - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Mobile for Pocket PC 2003 or later - RAM 64 MB , Microsoft Windows CE 4.2 or later - RAM 64 MB , Microsoft Windows Vista / XP / 7 / 8 - 750 MHz - RAM 1 GB - HD 10 GB , Microsoft Windows Embedded Handheld 6.5 - RAM 64 MB
Additional Requirements
DVD-ROM, network adapter, 1280 x 768 monitor resolution
Technical support
Scroll to top
