BT.com
Wishlist
WASP InventoryControl Mobile License w/ DT90 Mobile Device
WASP InventoryControl Mobile...
£974.04
£974.04
Add to wishlist
Delivery
Standard Due date unavailable
The DT90 features the best ergonomics on the market paired with the most comfortable and durable pistol grip handle in the industry. With its 38-key functional keypad, the DT90 is the premier solution for applications in retail, warehouse, and logistics environments. Whether in the stock room or the sales floor, the DT90 reduces operator fatigue without compromising efficiency or reliability.
The DT90's user interface comes equipped with at 3.2" high-visibility, color graphic display and an inclined scan engine so data on the screen can be viewed simultaneously while scanning barcodes. Offered with Microsoft Windows CE 6.0, the DT90 is powered by a 624 MHz microprocessor with 32-bit coprocessor. Its internal components are protected by a ruggedized housing that is sealed against moisture and dust and is capable of resisting multiple 5 foot drops to concrete. The DT90's integrated laser scanner can read all standard one-dimensional (1D) barcodes including GS1 Databar linear barcodes.
Wasp DT90 - data collection terminal - Win Embedded Handheld 6.5 - 512 MB - 3.8" - with Additional Mobile Device License IC
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Handheld 6.5
Display
3.8" colour TFT - 800 x 480
Marvell PXA320
Processor Clock Speed
806 MHz
Storage
512 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g/n
Camera
5 Megapixel (rear)
Barcode Reader
Yes (laser)
Barcodes
Code 93, Matrix 2 of 5, Code 39, ISBT 128, GS1 DataBar, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, ITF, TLC39, Australian Post, British Post, Canadian Post, IATA 2 of 5, UPC-E1, EAN-UCC Composite, ITF-14
Battery Run Time
Up to 8.14 hours
4 cm x 17.7 cm x 7.4 cm
390 g
1 year warranty
Bundled with
Operating System
Bundled with
Display
3.8" colour TFT
Resolution
800 x 480
Marvell PXA320
806 MHz
Storage
512 MB
RAM
256 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
802.11a/b/g/n
Camera
Resolution (MP)
5 Megapixel (rear)
Input Device
Touch-screen, 26 keys numeric keyboard
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
System Requirements for PC Connection
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
Expansion and Connectivity
Expansion Slots
1 x microSDHC
Lithium Ion
2200 mAh
Run Time
Up to 8.14 hours
Power adapter, stylus
USB cable
VCCI, BSMI, CCC, FCC, RoHS, IP65
4 cm
17.7 cm
7.4 cm
390 g
Service & Support Details
Limited warranty - 1 year , Technical support - lifetime
-10 °C
50 °C
5 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Scroll to top
