BT.com
Wishlist
WASP CCD Keyboard Wedge Scanner for PC
WASP CCD Keyboard Wedge Scanner for...
£81.15
42 in stock
£81.15
Add to wishlist
Delivery
Standard 3-5 working days
Wasp Bar Code CCD Scanner is the most popular solution for scanning bar codes. Its ease-of-use and durability make the CCD a favorite with customers. Wasp Bar Code CCD Scanner simply plugs between your keyboard and computer. This Scanner allows you to scan into any Windows, DOS, NT, or Mac application. Automate your data collection tasks with this easy-to-use, one-touch scanner.
Wasp CCD Scanner - barcode scanner
Barcode scanner - handheld - keyboard wedge
Scan Element Type
CCD
Scan Speed
50 scan / sec
Wired
Microsoft DOS, Microsoft Windows 3.x/95/98, Microsoft Windows NT, Microsoft Windows Millennium Edition, Microsoft Windows 2000 / XP
8.3 cm 19.1 cm
0.2 kg
Barcode
Interface Type
Keyboard wedge
Scan Element Type
CCD
Light Source Wave Length
660 nm
Scan Mode
Hand-held
Scan Speed
50 scan / sec
Decode Capability
Code 39, UCC/EAN-128, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
Wired
1 x keyboard
1 x keyboard cable - 2.4 m
FCC Class A certified
8.3 cm
19.1 cm
0.2 kg
50 °C
20 - 85%
Accessories
WASP WCS3900 CCD Scanner Stand
Quicklinx: 62TP | In Stock
£15.70
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
1* don't bother
Reviewed by chris brown on 02/02/2006
takes multiple attempts to scan even large high quality barcodes - not a chance if the barcode is slightly damaged. Sometimes the keyboard stops working after restarting the computer.
Scroll to top
