BT.com
Wishlist
WASP 2905 Pen Barcode Scanner
£95.70
7 in stock
£95.70
Add to wishlist
Delivery
Standard 3-5 working days
Whether you need quick access to data from an invoice, membership card, or any barcoded material, the Wasp WWR2900 series pen barcode scanner is the perfect tool for repetitive data entry. The WWR2900 pen barcode scanner is a reliable, cost-effective way to read barcodes. Scanned data appears on your screen as if you typed it from your keyboard. Scan data into any DOS or Windows application. It takes just minutes to set up. Increase your productivity and reduce costly data entry errors with the easy-to-use WWR2900 series barcode scanners.
Wasp WWR 2905 Pen Scanner - barcode scanner
Barcode scanner - handheld - wand - USB
Scan Element Type
Wand
Wired
Microsoft Windows 95, Microsoft Windows 98, Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP
Barcode
Interface Type
USB
Scan Element Type
Wand
Decode Capability
Code 93, Code 39, UCC/EAN-128, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, MSI-Plessey
Wired
1 x USB - Type A
1 x USB cable - 1.8 m
Scroll to top
