BT.com
Wishlist
Wacom Intuos Pro Large
£361.44
£361.44
Add to wishlist
Delivery
Standard Due date unavailable
The Wacom Intuos Pro pen tablet combines Wacom's fine pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities.
Get the most from your creative software with your favorite pre-selected shortcuts. The Intuos Pro even detects the software you're using and offers optimal selections. Quickly access all your shortcuts through the customizable ExpressKeys and touch ring. Stay focused with the express view display and radial menu. Discover intuitive navigation at the touch of your fingers: pan, zoom, rotate and navigate naturally with gestures, or create your own multi-touch shortcuts.
Wacom Intuos Pro Large - digitiser - USB - black
Digitiser
Wireless, wired - USB
Orientation
Right and left-handed
48.7 cm x 31.8 cm x 1.2 cm
1.8 kg
English, Spanish
Movement Detection Technology
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 lpi
Programmable buttons, finger-sensitive Touch Ring, soft rubber grip, multi-touch digitiser, ExpressKeys, -/+ 60 levels tilt recognition
1 x USB cable - 2 m
Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Apple MacOS X 10.6.8 or later, Windows 8
Digitiser
Orientation
48.7 cm
31.8 cm
1.2 cm
1.8 kg
English, Spanish
Input Device
Wireless, wired
USB
Electromagnetic
Buttons Qty
8
Movement Resolution
5080 lpi
Pressure Levels
2048
Active Area
32.5 cm x 20.3 cm
1 x USB - 4 pin USB Type A
Pen stand, pen tip nib removal tool, nibs (10 pcs.), colour identification rings, stylus pen
1 x USB cable - 2 m
Software Included
Drivers & Utilities
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Damaged stock - Item is new but has packaging damage
Ref: 91SL 035976
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£268.36
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
