Click to visit BT.com
BT.com
Wishlist
Wacom Intuos 4 - XL CAD Edition
Intuos 4
Quicklinx: 5HQFWS00
Mfr#: PTK-1240-C
Ever asked yourself how characters, emotions and ideas come to life - whether through photography, illustration, 3D-design, animation or the fine arts? The answer is a ground-breaking innovation that redefines the pen tablet category: Intuos4 by Wacom. Built for creative professionals it delivers probably the most natural drawing experience you can imagine. The 2,048 levels of pressure sensitivity capture even the slightest nuance of pressure. Its ergonomic, ambidextrous design was developed for hours of hard work. It offers customizable ExpressKeys - including OLED-displays showing the current function setting of each key. New radial menus enable fast access to shortcuts - with just a pen stroke. Scrolling, zooming and brush adjustments can be done with a fingertip thanks to the Touch Ring with toggle functionality. Try it. Discover for yourself where it all begins: Discover the world of Intuos4.
Wacom Intuos4 XL CAD - digitiser and cursor set - USB - black
Digitiser and cursor set
Wired - USB
63.2 cm x 46.2 cm x 2.8 cm
3.5 kg
Movement Detection Technology
Electromagnetic
Movement Resolution
5080 lpi
Accuracy
± 0.25 mm
Programmable buttons, eraser, finger-sensitive Touch Ring, 8 ExpressKeys, tilt sensitive
1 x USB cable - 2.5 m
Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.4.8 or later
Microsoft Certification
Compatible with Windows 7
2 years warranty
63.2 cm
46.2 cm
2.8 cm
3.5 kg
Input Device
Wired
USB
Electromagnetic
Movement Resolution
5080 lpi
Accuracy
± 0.25 mm
Pressure Levels
2048
Active Area
30.5 cm x 46.2 cm
1 x USB - 4 pin USB Type A
FCC Class B certified, VCCI Class B ITE
Software Included
Drivers & Utilities
