BT.com
Wishlist
Wacom Cintiq 13 Pen & Touch
Delivery
Standard Due date unavailable
Experience the power of a high-performance Cintiq in a compact, slim design. The Cintiq 13HD is an interactive pen display that allows you to create directly onto a 13.3" HD display. It offers you many of the advantages of the larger Cintiq, like the four time-saving, customizable ExpressKeys, the rocker ring, and the home button for easy shortcut access. Its high resolution HD 1920 x 1080 LED display features a 178° viewing angle and renders 16.7 million colors.
The detachable stand adjusts to three different working angles and you can also use the Cintiq 13HD flat on your desktop or in your lap. Wacom's powerful Pro Pen with 2048 levels of pressure sensitivity, tilt recognition, and a more comfortable, ergonomic design provides precise control and a better feel than ever. The Pro Pen comes in a compact carrying case that includes storage for the extra nibs and color rings that help you easily personalize and identify your pen. The Cintiq 13HD experience starts right away - with a simple setup.
Wacom Cintiq 13HD - digitiser - USB
Digitiser
Wired - USB
Display
LCD display - 13.3" - 1920 x 1080
Orientation
Right and left-handed
37.5 cm x 1.4 cm x 24.8 cm
1.2 kg
Movement Detection Technology
Electromagnetic
Buttons Qty
4
Movement Resolution
5080 lpi
Programmable buttons, pressure sensitive pen, eraser, 4 ExpressKeys, 2 side-switches, -/+ 60 levels tilt recognition, radial menu button, Rocker Ring, Precision Mode, Display Toggle
AC 120/230 V
Apple MacOS X 10.8 or later, Microsoft Windows 7 SP1 / Windows 8
Digitiser
Orientation
37.5 cm
1.4 cm
24.8 cm
1.2 kg
Input Device
Wired
USB
Electromagnetic
Buttons Qty
4
Movement Resolution
5080 lpi
Pressure Levels
2048
Active Area
29.9 cm x 17.1 cm
Display
LCD display
Diagonal Size
13.3"
Image Aspect Ratio
16:9
Pixel Pitch
0.0225 mm
Colour Support
16.7 million colours
Native Resolution
1920 x 1080
Image Brightness
250 cd/m²
Image Contrast Ratio
700:1
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Response Time
25 ms
1 x USB 2.0 - 4 pin USB Type A , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x power
Pen stand, remote control, nibs (9 pcs.), pen case, pen
C-Tick, BSMI, CB, FCC Part 15 B, CCC, FCC Part 15 C, RoHS, KCC, GOST-R, VCCI Class B
AC 120/230 V
Power Consumption
9 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Drivers & Utilities
Scroll to top
