Wacom Bamboo Stylus Duo - Stylus / ballpen - black, platinum silver
Standard Due date unavailable
A premium digital pen for the iPad, Bamboo Stylus delivers a high-end look, natural, weighted feel of a real pen, to give you capabilities for drawing, sketching and note taking on your iPad.
Just what you would expect from Wacom. Simple but elegant, Bamboo Stylus further enhances numerous applications designed for the iPad by allowing users to express themselves and personalize their work. The stylus brings a more accurate and precise way to take notes in meetings and classroom settings or to sketch out rough ideas while on the go. It gives creative thinkers the opportunity to be expressive and visualize their life.
Backed by Wacom's 25-plus years as the world's leading manufacturer of digital pen tablets and interactive pen displays, Bamboo Stylus is highlighted by its subtle design elements, sophisticated black and silver design with satin-textured metal body and balanced weighting. In addition, the fine tip gives the user more detail control.
The tip of the stylus is 25 % slimmer in diameter than most of the solutions on the market today. Combining ergonomic comfort and a firmer feel, Bamboo Stylus enriches the way in which users interact with their slates. Ideal for handwriting notes, giving a personal touch when editing documents, drawing, sketching and much more - users can now be even more creative.
Apps for iOS
Note taking :
Bamboo Paper - Take notes, draw or doodle. Always have your notebooks with you.
Goodreader - great tool for managing files combined with the ability to add comments or sign your name on PDF documents
iAnnotate - Add comments and marks to your PDF in a simple way
Adobe Ideas - great if you want to add your own embellishments to an image
Autodesk Sketchbook Pro - great to create artistic sketches with wide variety of brush settings
Doodle Buddy - if you are just looking for a simple doodle pad that you can scribble on with your friends then try this.
Paint :
ArtRage - great if you want to express your creative side
Inspire Pro - Paint and live your inspirations on your iPad
Apps for Android
Note taking:
Bamboo Paper - turn your media tablet into a paperless communication tool
Compatible with all media tablets using capacitive touch technology
Tested devices:
Samsung Galaxy Tab, 1st generation (limited compatibility, suitable for navigation purpose only)
Wacom Bamboo Stylus Duo - stylus / ballpen
Stylus / ballpen
Product Material
0.9 cm
13.6 cm
20 g
Stylus / ballpen
Product Material
0.9 cm
13.6 cm
20 g
Black, platinum silver
Scroll to top
