BT.com
Wishlist
Vogels Flat wall mount 50"-80"
Delivery
Standard Due date unavailable
Vogel's professional 5000 series wall mounts offer high levels of theft protection for flat displays used in public areas that cannot be continually supervised. This is a versatile product line that provides extra features for theft prevention and quick and easy installation. A sturdy lock secures displays effectively and very closely to the wall to prevent removal. These mounts have a clean and elegant look and take up a minimum amount of space, yet making the display easily accessible for display service. The unique built-in leveling function in the wall plate makes life a lot easier for installers. It helps them to correct the leveling during installation.
Vogel's Professional PFW 5500 - mounting kit
Mounting kit
Mounting Components
Wall bracket
101 cm 61 cm
Recommended Use
LCD / plasma panel
Recommended Display Size
50" - 70"
Max Load Weight
100 kg
101 cm
61 cm
AV Furniture
Mounting kit
Mounting Components
Wall bracket
Recommended Use
LCD / plasma panel
50" - 70"
Max Load Weight
100 kg
Scroll to top
