BT.com
Wishlist
Vision TM-TELE Telescopic Proj. Bracket
Vision TM-TELE Telescopic Proj....
£46.50
£46.50
Add to wishlist
Delivery
Standard Due date unavailable
The TM-TELE Techmount is a projector ceiling bracket for anchoring any data projector safety to a ceiling. The telescopic design allows fast deployment and adjustment without the need cut and drill the pole. It has a greater range than most other telescopic mounts and the pole can be removed for "flush-mounting" the projector as close to the ceiling as possible.
Vision Techmount TM-TELE - ceiling mount
Ceiling mount
Adjustable Height
44-73.5 cm
Tilt
Recommended Use
Projector
Max Load Weight
10 kg
Satin white
2 years warranty
Adjustable Height
44-73.5 cm
Satin white
AV Furniture
Ceiling mount
Mounting Components
Ceiling mount, telescoping rod
Recommended Use
Projector
Cable Management
Cable Management System (CMS)
Tilt
Adjustments
Pitch
Max Load Weight
10 kg
Adjustable height, quick release
Scroll to top
