BT.com
Wishlist
Vision TM-IFP Portable Conversion Kit
Vision TM-IFP Portable Conversion...
£253.50
More than 50 in stock
£253.50
Add to wishlist
Delivery
Standard 1-3 working days
If the flat-panel is a shared resource Vision offer a dolly which converts the assembly into a portable solution. The weighted base is 950mm wide by 660mm deep and uses big 100mm wheels to maximize stability.
Vision - mounting component
Mounting component
Mounting Components
Weighted base
95 cm x 66 cm
13 kg
Wheels Qty
4
95 cm
66 cm
13 kg
AV Furniture
Mounting component
Mounting Components
Weighted base
Wheels Qty
4
Wheel Diameter
10 cm
Brakes Qty
4
Scroll to top
