BT.com
Wishlist
Vision TechConnect HDMI-on-IP Matrix Rx
Vision TechConnect HDMI-on-IP...
£223.50
£223.50
Add to wishlist
Delivery
Standard Due date unavailable
Designed for video signage applications the Techconnect Matrix allows distribution of HDMI content over an existing managed LAN infrastructure. Because of this the cost of deployment is radically lower than bespoke AV distribution systems.
VISION Techconnect2 MATRIX HDMI-OVER-IP MATRIXING Receiver - video/audio/serial extender
Video/audio/serial extender - RJ-45 / 19 pin HDMI Type A
External
Australia, United Kingdom, United States, European Union
Max Transfer Distance
100 m
AC 120/230 V
14.1 cm x 11.5 cm x 2.6 cm
440 g
2 years warranty
External
White
Wired
Max Resolution
1920 x 1080
100 m
Power over Ethernet (PoE)
HDCP 1.3
1 x HDMI - 19 pin HDMI Type A female , 1 x network - RJ-45 female , 1 x RS-232
External power adapter
5 Watt
Software Included
Drivers & Utilities
14.1 cm
11.5 cm
2.6 cm
440 g
-5 °C
30 °C
5 - 90% (non-condensing)
Accessories
£7.58
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£21.64
£41.53
£56.29
Scroll to top
