BT.com
Wishlist
Vision TechConnect 10m 2-phono Cable
Vision TechConnect 10m 2-phono...
£17.59
More than 50 in stock
£17.59
Add to wishlist
Delivery
Standard 3-5 working days
A major cost component of cables is copper, so cheap cables have less copper and a thick outer cable jacket to fool the buyer into thinking they are getting something they are not. Compromising can result in cables which don't support high quality Audio and results in flagging and ingress of noise interference. The cross-sectional area of Tecconnect cable conductors allows sufficient current-carrying capacity to support high quality transmission of audio signals, and the shielding is evenly wound.
One end or the TC2-10M2PHO cable is pre-terminated with a phoenix captive screw connector ready to plug into back of a Techconnect V2 module and 2 RCA (Phonon) molded plugs on the other end that can be simply plugged into your TV, DVD Player, Amplifier or other compatible device.
Techconnect cables give you the speed of a pre-terminated system with the flexibility you sometimes need so just in case you need to shorten a cable or to pull a cable through a small hole or cavity? Or if you need more than 7 meter but less than 10 m and no where to hide the excess cable just unscrew and remove the phoenix connector, cut the cable to length, prepare the wire ends for re-termination to the Phoenix screw connector.
VISION Techconnect 2 - video / audio cable - 10 m
Cable
Video / audio cable
American Wire Gauge (AWG)
26
Length
10 m
Connector
Bare wire
Connector (Second End)
2 x RCA - male
Molded
Cable Type
Video / audio cable - molded
26
Length
10 m
Connector
Bare wire
2 x RCA - male
Scroll to top
