BT.com
Wishlist
Vision SP-5000 Pair Column Speakers
Vision SP-5000 Pair Column...
£93.33
38 in stock
£93.33
Add to wishlist
Delivery
Standard 1-3 working days
The SP-5000 has an integrated circuit which decodes audio received via USB and sends the analog audio signal to an installed Techconnect amplifier or an external amplifier. Simply route the USB from the PC to the loudspeakers. The PC will recognize them as an audio output device.
An attractive curved chassis and grille compliment the finish of an interactive whiteboard or flat panel installation. When connecting USB to an interactive whiteboard the decoder must be powered. Power can be shared with a Techconnect Amplifier power supply if installed.
Vision SP-5000 - speakers
Speakers
13 cm x 17 cm x 52 cm
System Components
2 speakers
Speaker Type
Passive
Nominal Output Power
20 Watt
Frequency Response
90 - 20000 Hz
Nominal Impedance
8 Ohm
Speaker System Details
2 - 20 Watt - 90 - 20000 Hz - 8 Ohm
Silver
2 years warranty
Speakers
13 cm
17 cm
52 cm
Enclosure Colour
Silver
Speaker System
System Components
2 speakers
Speaker Type
Passive
20 Watt
Frequency Response
90 - 20000 Hz
Nominal Impedance
8 Ohm
Sensitivity
86 dB
Recommended Placing
Wall-mountable
Speakers Included
2 - 20 Watt - 90 - 20000 Hz - 8 Ohm - wall-mountable - wired
Driver Details
Woofer driver - 3.5" , 1 x tweeter driver - 1" - silk
Wall mounting brackets
2 years warranty
Service & Support Details
Scroll to top
