BT.com
Wishlist
Vision K/VISION AV-1600 Stereo Amplifier
Delivery
Standard Due date unavailable
Vision AV-1700 is a 4-channel digital stereo mixer amplifier bundle with Vision CS-1600 discrete flush ceiling tile mount speakers. The AV-1700 amplifier is compact, flexible, easy to use and uses no power at idle. Rated at 2 x 30 W RMS per channel at 8 ohms impedance. The Vision 30 W stereo AV-1700 power amplifier with 4 x stereo inputs/1 x stereo pre-output/1 x balanced microphone input with phantom power.
Vision AV-1700 + CS-1600 - audio system
Audio system
Components
Amplifier, speaker system
Enclosure Colour
White
Sound Output Mode
Stereo
Audio Specifications
Amplifier - 50 - 18000 Hz - 75 dB
Speakers
2 x speaker - external - 30 Watt - 70 - 20000 Hz
AC 120/230 V
3 years warranty
Audio system
Dimensions (WxDxH) / Weight
Speaker system: speaker: 23 cm x 12.8 cm 1.9 kg , Amplifier: 22 cm x 15.4 cm x 4.4 cm / 1.2 kg
Enclosure Colour
White
Audio System
Components
Sound Output Mode
Stereo
Functions
Amplifier
Amplifier - Response Bandwidth - 50 - 18000 Hz - SNR - 75 dB
Input Impedance
47 kOhm
Input Sensitivity
500 mV
Amplifier Output details
30 Watt - 8 Ohm - THD 2% - 2 channels ( main )
Speaker System
Speakers
2 x speaker - 2-way - external - 30 Watt - 70 - 20000 Hz - 8 Ohm - wired
Driver Details
Speaker: 1 x woofer driver - 6.5" , Speaker: 1 x tweeter driver - 1" - silk
Connector Type
3 x audio line-in ( RCA x 2 ) - rear , Microphone ( XLR ) - rear , Audio line-out ( RCA x 2 ) - rear , Audio line-in ( mini-phone stereo 3.5 mm ) - rear , Audio line-in ( mini-phone stereo 3.5 mm ) - front , 2 x speakers output ( terminal block (clamp) ) - rear , Serial - rear
Audio cable kit, remote control, speaker cable kit
AC 120/230 V
125 Watt
Limited warranty - 3 years
Scroll to top
