Click to visit BT.com
BT.com
Wishlist
ViewSonic VX2703MH-LED 27" 3.4ms HDMI MM DVI Monitor
Quicklinx: 88V6WS00
Mfr#: VX2703MH-LED
Essential accessories
ViewSonic's VX2703mh-LED features a 27" widescreen LED panel monitor with up to 40% energy saving compared to a regular 27" monitor. Environmentally friendly mercury free VX2703mh-LED offers Full HD 1920 x 1080 resolution, HDMI and DVI inputs with HDCP, integrated power, 3ms response time, 10,000,000:1 MEGA dynamic contrast ratio, and built-in speakers with SRS Premium Sound. It is ideal for both home and office with a contemporary thin bezel design. The aspect ratio adjustment feature automatically senses the input single and will not stretch a 4:3 signal, but instead will position the image in the middle of the screen with side bars.
ViewSonic VX2703mh-LED - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
43 kWh
Power Consumption (On mode)
29 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
1200:1 / 20000000:1 (dynamic)
Response Time
3.4 ms
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
64.4 cm x 17.4 cm x 43.6 cm - with stand
5.4 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, E-Standby, UkrSEPRO, KC, ERP
Display Type
Energy Class
Class A
43 kWh
29 W
Diagonal Size
27"
Viewable Size
27"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
Response Time
3.4 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, input select, colour temperature, aspect control
OptiSync, sRGB colour management, Eco-Mode, ClearMotiv II, SRS Premium Sound, Mega Dynamic Contrast Ratio
5.4 kg
Audio
Speakers - stereo - integrated
HDMI ( HDCP ) , VGA , DVI-D ( HDCP ) , Audio line-in , Audio line-out
Mechanical
Tilt
Tilt Angle
-3/+16
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
Internal
AC 120/230 V ( 50/60 Hz )
36 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
Without stand - width: 64.4 cm - depth: 5.6 cm - height: 39.1 cm - weight: 4.9 kg , With stand - width: 64.4 cm - depth: 17.4 cm - height: 43.6 cm - weight: 5.4 kg
EPEAT Compliant
EPEAT Silver
20 - 90% (non-condensing)
