BT.com
Wishlist
ViewSonic VX2452MH 23.6" 1920x1080 2ms VGA DVI-D HDMI LED Monitor
Delivery
Standard Due date unavailable
ViewSonic's VX2452MH is a 24" (23.6" viewable) Full HD, glossy-finish display that offers the ultimate visual experience for gaming and multimedia entertainment. The VX2452MH features ClearMotivII technology that delivers 2 ms ultra-fast response time for blur-free images during extreme gaming, and an ultra-high 50M:1 MEGA dynamic contrast ratio for sharp, crisp color performance for enjoying movies. Integrated D-sub, DVI and HDMI inputs provide flexible connectivity for high-definition multimedia devices and gaming consoles, and dual built-in 2-watt stereo speakers complete the package for multimedia enjoyment. With a VESA-mountable design, the VX2452MH offers flexible mounting options for any of your gaming and video entertainment needs.
ViewSonic VX2452MH - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
2 ms (gray-to-gray)
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
55.92 cm x 22.25 cm x 43.17 cm
3.8 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, SASO, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, UkrSEPRO, ERP, SVHC
3 years warranty
Display Type
Diagonal Size
24"
Viewable Size
23.6"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Response Time
2 ms (gray-to-gray)
Vertical Refresh Rate
50 - 75 Hz
Horizontal Refresh Rate
24 - 82 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, colour balance, input select
HDCP, Eco-Mode, ClearMotiv II, game mode, Mega Dynamic Contrast Ratio, a-Si technology
55.92 cm x 22.25 cm x 43.17 cm - with stand
3.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
VGA , HDMI (HDCP) , DVI-D (HDCP) , Audio line-in , Headphones
Mechanical
Tilt
Tilt Angle
20
Flat Panel Mount Interface
100 x 100 mm
1 x VGA cable , 1 x DVI cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
External
21.5 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 55.92 cm - depth: 22.25 cm - height: 43.17 cm - weight: 3.8 kg , Without stand - width: 55.92 cm - depth: 5.3 cm - height: 35.67 cm - weight: 3.5 kg
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
10 - 90% (non-condensing)
Scroll to top
