BT.com
Wishlist
ViewSonic VX2270smh-LED 22" IPS HDMI DVI VGA Speakers Monitor
Delivery
Standard Due date unavailable
DESCRIPTION
Designed with frameless bezel and touch controls,the ViewSonic VX2270Smh-LED sets a new milestone in display design delivering a cutting-edge, trendy quality to any living space or office. With Full HD 1080P, 30,000,000:1 dynamic contrast ratio, up to 7ms response time and SuperClear™ IPS, the VX2270Smh-LED brings vivid and sharp images to life with remarkable image quality and wide viewing angles. An HDMI port provides high resolution image/video connection with devices for gaming, graphics, and HD entertainment.A pair of speakers powered by SRS Premium Sound® delivers true-to nature high-end stereo, complementing this superior display perfectly for a wide variety of applications.
Frameless and slim bezel with touch control
The frameless bezel on VX2270Smh-LED features an elegant and glossy finish to complement any home or office. The sleek and seamless touch function key provides a simple and intuitive touch experience, making screen adjustment easy and fast. The VX2270Smh-LED is a stylish addition to any home or office.Frameless or thin screen means that the screen goes right up to the edge of the bezel so therefore there is no edge between the frame and the screen
Full HD 1080p Resolution
The brilliant pixel quality of the 1920x1080 Full HD panel reproduces refined and natural image quality to meet the requirements of computer applications, graphics, gaming and HD video entertainment. The VX2270Smh-LED is an ideal fit for home entertainment and office works.
SRS Premium Sound® surrounding stereo gives you BASS !!
Dual 1.5-Watt speakers, powered by SRS Premium Sound® surround stereo delivers audiophile quality sound for anyone seeking a supreme audio performance and gaming experience. SRS Premium Sound® produces deep rich bass and crisp highs with no requirement to connect external speakers, maximizing desk space to let the all-immersiveaudio journey begin. What they can do :
  • Premium audio experience for music, video and games on the PC
  • Immersive surround sound experience from internal or external speakers and even headphones
  • Greater volume for notebook speakers without degrading audio quality
  • Crystal clear dialog
  • Deep, rich bass
HDMI Input
The HDMI Interface on the VX2270Smh-LED allows flawless streaming with a variety of media devices, including computers, set-top boxes,Blu-ray disc players, HD digital cameras, gaming consoles and many others. HDMI enables image/video streaming to be delivered in a true high definition experience.
SuperClear™ IPS wide-viewing angles and makes MS rating around 2/3MS
Industry-leading SuperClear™ IPS Wide Viewing Angles technology delivers 178° viewing angles from the horizontal and vertical with an accurate, vibrant, and dynamic image. Brightness levels are consistent across all viewing angles with no distortion or decay. Basically IPS panels create Sharper, Crisper images which off sets the 7/8MS rating to about 2/3ms
MAIN FEATURES
Screen: 22" IPS super clear & LED backlit technology
Res: 1920x1010 FULL HD 1080p
Contrast: 30,000,000 Dynamic : 1000:1 Standard
Sound: 1.5W x2 powered by SRS technology
Features: HDMI, VGA , DVI
Frameless: Screen is flush with the bezel
Warranty: 2 Years - Manufacturer warranty
ViewSonic VX2270Smh-LED - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class A
Energy Consumption per Year
28 kWh
Power Consumption (On mode)
19 W
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 30000000:1 (dynamic)
Response Time
7 ms (grey-to-grey)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
49.95 cm x 39.2 cm x 17.95 cm
3.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
FCC Class B certified, UL, C-Tick, BSMI, cUL, ICES-003, NOM, SASO, TUV S, CB, CCC, PSB, RoHS, WEEE, GOST-R, UkrSEPRO, ERP
3 years warranty (Austria, Germany, Switzerland - 2 years)
Display Type
Energy Class
Class A
28 kWh
19 W
Diagonal Size
21.5"
Viewable Size
21.5"
Panel Type
IPS
Aspect Ratio
Widescreen - 16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
Response Time
7 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, colour balance, input select, colour temperature, H-size, aspect control
HDCP, SuperClear
49.95 cm x 39.2 cm x 17.95 cm - with stand
3.6 kg
Audio
Speakers
DVI-D , VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+20
Security lock slot (cable lock sold separately), 3H hard-coating
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
External
26 Watt
Power Consumption Stand by / Sleep
1 Watt
On / Off Switch
No
Included Software
ViewSonic Wizard
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years , Limited warranty - backlight - 3 years
20 - 90% (non-condensing)
Scroll to top
