BT.com
Wishlist
ViewSonic VX2263SMHL-W 22" 1920x1080 2ms VGA HDMI IPS LED Monitor
Delivery
Standard Due date unavailable
The ViewSonic VX2263Smhl-W is a Full HD 1080p display designed for entertainment, gaming, and multimedia applications. An MHL port enables seamless connectivity, and simultaneous battery charging, of MHL-enabled mobile devices to facilitate easy content sharing and mobile gaming on a larger screen. Additional versatile connectivity options include HDMI and VGA ports for added convenience in traditional PC environments. In addition, ViewSonic’s SuperClear image enhancement technology delivers superior color performance with excellent color reproduction, while a 50M:1 MEGA Dynamic Contrast Ratio and integrated stereo speakers provide great multimedia and entertainment performance. Additional features include Eco-mode for increased energy savings, as well as a 100x100mm VESA mount for more flexible installation options. A premium design includes a frameless edge-to-edge glass faceplate and slim bezel beneath the glass, making the VX2263Smhl-W a stylish addition to any desktop.
ViewSonic VX2263SMHL-W - LED monitor - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
20 W
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 50000000:1 (dynamic)
Response Time
14 ms
Input Connectors
HDMI, VGA, MHL
Speakers
Integrated
Screen Coating
Anti-glare, 3H Hard Coating
White
49.88 cm x 16.4 cm x 38.77 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, UL, ICES-003, NOM
2 years warranty
Display Type
Energy Class
Class A
29 kWh
20 W
Diagonal Size
22"
Viewable Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080
Brightness
250 cd/m²
Contrast Ratio
Response Time
14 ms
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
24 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
Controls & Adjustments
Volume, brightness, contrast, H/V position, input select
SuperClear, a-Si technology
White
49.88 cm x 16.4 cm x 38.77 cm - with stand
2.9 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1.5 Watt
HDMI , VGA , MHL / HDMI , Audio line-in , Audio line-out
Mechanical
Tilt Angle
-5/+15
Flat Panel Mount Interface
100 x 100 mm
Wall mountable, tilt adjustment
1 x VGA cable , 1 x HDMI cable , 1 x audio cable
Backlight Life
30,000 hours
Power Supply
Internal
20 Watt
On / Off Switch
No
Included Software
Drivers & Utilities, ViewSonic Wizard
Dimensions & Weight Details
With stand - width: 49.88 cm - depth: 16.4 cm - height: 38.77 cm - weight: 2.9 kg , Without stand - width: 49.88 cm - depth: 4.1 cm - height: 31.24 cm - weight: 2.6 kg
10 - 90% (non-condensing)
Scroll to top
